winterck
Dec 01, 2024Aspirant
how to access only the 4.2 Ghz to connect a robot on 2016 nighthawk x6 AC 3000 router?
My Nighthawk X6 AC 3000 router has triband wifi. I want to bypass the 5 Ghz and connect my new Roborock mop/vac to the 2.4 Ghz band; but keep getting a "can not connect" message. How do I physically ...
winterck
Dec 03, 2024Aspirant
Thank you for that; I wasn't aware. Don't see were I can delete that from this post now. The router is R7900.
I am feeling I will abandon it and just purchase a more up to date model and scrap this one anyway.
I appreciate all the help.
Kitsap
Dec 03, 2024Master
Even with a newer router, the same basic concepts still apply. Make sure you have separate SSIDs for your 2.4 and 5 GHz Wi-Fi bands and make sure your phone is connected to the same band as you are trying to connect to your robot.
