Cynyster's avatar
Jul 29, 2021
How to access R7000 when set as an access point?
I just set up my "old"  R7000 as an access point to extend the wifi reach of my R8000.
Just so we are clear.   IT WORKS. I am able to connect to the R7000 wifi and get to the internet.
The issue I am having is I have no way of connecting to the R7000 to administer it
and  I have no way of seeing what is connected to it.
Any suggestions?
  • I think I have come up with a "Work Around"
    I connected a laptop directly to the R7000 and logged in  and enabled the "Remote Management" Option
    With that enabled  I can login the router  and see what is connected to it.
  • > The issue I am having is I have no way of connecting to the R7000 to
    > administer it
       Sure you do; you just don't know what it is.
       From a device which is connected directly to the R7000-as-WAP, so
    that the R7000-as-WAP can intercept its DNS requests, the "routerlogin"
    names are supposed to work.
       More reliably, and from anyplace on your LAN, you should be able to
    specify the (LAN) IP address of the R7000-as-WAP.  You should be able to
    find that address from an Attached Devices report on your main router.
       For convenience, you can reserve some memorable address for the
    R7000-as-WAP on the main router (Address Reservation), so you wouldn't
    need to search for it every time something restarts.
       I know nothing, but I wouldn't bet that its Attached Devices report
    would show only devices which are connected directly to it.  I'd expect
    the Attached Devices report on the main router to show all the devices
    on the LAN, with the devices wjich are connected directly to the
    R7000-as-WAP being classified as "wired", because that's how the main
    router sees them.
    • Cynyster's avatar
      Cynyster
      Guide
      Sadly  this is not the case.  None of the devices connected to the wireless access point (R7000)  show up on the "connected" device list.
      I do not mind this  if I can connect to the R7000 (which of course  I do not seem to be able to)
      • Cynyster's avatar
        Cynyster
        Guide
  • michaelkenward's avatar
    michaelkenward
    You can get in by finding the IP address that the router has allocated to your R7000.
    There are various ways of doing this, including visiting the controls of the router itself and looking for the IP address in attached devices.
    You can also use something like the Netgear desktop genie for your operating system.
    genie | Product | Support | NETGEAR
    Your claimed "solution" does not actually make sense.
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    That includes Remote Management.
    • Cynyster's avatar
      Cynyster
      Guide
      I am responsible for what I say,  not what you understand.
      I connected to the R7000 directly... (aka take a laptop. connect a Cat5 cable between the laptop and the R7000)
      I set the R7000 so that remote administration was enabled.
      Now I can connect to the R7000  with any computer on my network.
      Now that I can login to the R7000 I can  monitor the devices that are connecting to the R7000....
      If you need a more detailed explaination please  ask your nearest 12 year Old
        michaelkenward
        That is a direct connection. It is an excellent way to get into the controls of the R7000 in AP mode.
        It is not "remote administration", a term that Netgear does not use.
        Remote Management, Netgear's description, which was mentioned in an earlier message, is designed to let you use the Internet to access your devices from somewhere out in the world. As the manual puts it:
        "The remote management feature lets you access your router over the Internet to view or change its settings."
        Enabling your router's remote management | Answer | NETGEAR Support
        They have moved access to that feature in some devices. It is now in Web Services Management.
        This is the feature that at least two of us, along with Netgear's documentation, think that Remote Management does not work with a router in AP mode. (It certainly doesn't here.)
        Plugging a cable into the R7000 does not count as connecting over the Internet.
        I mention this only to warn anyone who sees the "Solved" flag on this conversation and tries to go down the same road. They might get lost.
