TL35537's avatar
TL35537
How to add the AC1200 WiFi Range Extender to the AC2200 Tri-Band WiFi Range Extender?
Source:  Verizon WiFi device
First extender:  Netgear Nighthawl X 4S AC2200 Tri-Band WiFi Extender (Model EX7500)
Question:  How can I add my old AC1200 (model EX6150) for use inside my bedroom?
  • plemans's avatar
    so you're currently going:
    Verizon wifi device (model?)---->EX7500
    and you want to conenct another extender to the EX7500
    What error/problem are you running into?
    You can daisy chain extenders. I wouldn't recommend doing it but it can be done.
    • TL35537's avatar
      TL35537
      Yes, that's exactly what I am looking to do.  The Verizon router is all the way in the living room.  The EX-7500 is half way in the middle of the apartment.  I need to put the EX-6150 inside my bedroom, which is at the end of a long hallway.
      How do I configure it?  Thanks in advance for your help!
      • plemans's avatar
        TL35537 wrote:
        Yes, that's exactly what I am looking to do.  The Verizon router is all the way in the living room.  The EX-7500 is half way in the middle of the apartment.  I need to put the EX-6150 inside my bedroom, which is at the end of a long hallway.---dual/single band extenders cut throughput 50% by the very nature of how they work. If your computer is in the same room as the (EX6+++ extender, you'd be better off connecting directly to the EX7500.
        How do I configure it?  Using the same guide from the installation support site.
