Swapnilr15's avatar
Swapnilr15
Follower
Jan 20, 2021
How to bind mac id to ISP
Dear Team,
Please asist me how to bind the Router MAC Id to ISP,
1 Reply
  • schumaku's avatar
    schumaku
    Not fully convinced I understand your question - guess you want to use the new router using the WAN/Internet adapter MAC address, because some ISP bind the ISP has locked the CPE to a single MAC address.
    This is not possible with the Nighthawk app - login using a web browser to the R8000.
    NETGEAR Nighthawk X6 AC3200 Tri-Band WiFi Router Model R8000 User Manual p.23 "Manually Set Up the Internet Connection", then p.24
    10. Select a Router MAC Address radio button:
    • Use Default Address. Use the default MAC address.
    • Use Computer MAC Address. The router captures and uses the MAC address of the
    computer that you are now using. You must use the one computer that the ISP allows.
    • Use This MAC Address. Enter the MAC address that you want to use.
