greenpid
May 08, 2016Aspirant
How to block Ip address xxx.xxx.xxx.xxx Port 80 which is attempting to access a secure web server
I have a web server which an external IP address is trying to access. (Not getting through) but Filling my Logs up As this address is a comercal company I am goignt to send a request to stop the prob...
- May 08, 2016
The router should already be blocking access unless you set up port forwarding, so there is nothing more you can do on your end. Contacting the company is the correct, next step.
