longitvn
Aug 30, 2021Aspirant
how to block VPN add-on on chrome, firefox..... or other webbrowser
Dear support team, I am using Netgear Nighthawk R7000 router combined with Circle solution to manage the use of children's Internet. I am having problems when my child uses "VPN add-on" on Google Ch...
Aug 30, 2021Guru - Experienced User
No security method is going to be 100%
Kids are great at finding out ways around things.
you might start managing his google chrome extentions.
https://support.google.com/chrome/a/answer/6177431?hl=en
Or setting up admin privleges on pc/laptops/phones and restricting apps.
Or simply take the devices away when you find them working around your restrictions.
Or have a discussion on why you're restricting these sites and the repurcussions/punishments for going around them. .
I had a friend that banned their kid from tiktok so their kid use one of their friends old phones while at school to get around it.
Sure, they didn't use it at home but it didn't mean they weren't using it elsewhere or even sneaking the phone home and jumping on a neighbors wireless.
So you can restrict all you want. But when they start working around the boundaries, they're going to find a way to access what they want somehow. It might be time to start working with them.
sorry, I'm going through it with one of my monsters and I either lock everything down so tight that nothing works right or I work with them and have frank discussions (not always comfortable discussions) and proper sites/usage and the reasons for it. And we still have set backs and removal of electronics. and thats what I can control at home.
- longitvnAug 30, 2021Aspirant
Thanks you so much !
However at this time I am looking for an optimal solution for that. Absolutely prohibit playing games and social networks to practice together for learning. Can someone help me? pls Thanks plemans ,
- michaelkenwardAug 31, 2021Guru - Experienced User
Unlikely, because you are trying to achieve something that may not be possible. Nothing will block a determined kid with enough knowledge to go our and find escape routes from any defences you install.
You could investigate subscription services like Circle and Armor to manage your network.
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Circle needs a subscription.
Here's another one that costs money:
What is the NETGEAR Armor Bitdefender Total Security feature? | Answer | NETGEAR Support
