longitvn
Aug 30, 2021Aspirant
how to block VPN add-on on chrome, firefox..... or other webbrowser
Dear support team, I am using Netgear Nighthawk R7000 router combined with Circle solution to manage the use of children's Internet. I am having problems when my child uses "VPN add-on" on Google Ch...
longitvn
Thanks you so much !
However at this time I am looking for an optimal solution for that. Absolutely prohibit playing games and social networks to practice together for learning. Can someone help me? pls Thanks plemans ,
michaelkenward
Aug 31, 2021Guru - Experienced User
Unlikely, because you are trying to achieve something that may not be possible. Nothing will block a determined kid with enough knowledge to go our and find escape routes from any defences you install.
You could investigate subscription services like Circle and Armor to manage your network.
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Circle needs a subscription.
Here's another one that costs money:
What is the NETGEAR Armor Bitdefender Total Security feature? | Answer | NETGEAR Support
