legnet
Sep 04, 2021Follower
How to Change channel on 2.4 gh band
How can I change the channel that my 2.4 ghz band runs on
- microchip8Master
Go to http://routerlogin.net or http://192.168.1.1 and change whatever you want
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the manual for something like Specify Basic WiFi Settings.Hard to be more specific without knowing what device you are playing with.
