2Schroyers
Nov 13, 2021Follower
How to Change Channel on Wifi Router
Nov 13, 2021Guru - Experienced User
follow this guide
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
- michaelkenwardNov 14, 2021Guru - Experienced User
...and read the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
For more specific stuff on your C7000, you might get more help, and find earlier questions and here:
Cable Modems & Routers
