molaver
Nov 21, 2021Tutor
How to change login address?
I am changing internet providers and will have a new email address. How can I change the address to log into the Netgear forum and the Blackhawk app with the new email address?
You might have to tell us what your hardware is before you can get any useful answers.
If your ISP has changed, then you should reset your router, whatever it is, and set it up again from scratch. You need to do that to wipe out the settings from your old ISP.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
1 Reply
Support | NETGEAR
