SJPWOLFF
Mar 06, 2022Aspirant
How to change my password for netgear.com
Hi there. I've spent 30 minutes looking around the options on the website to change my password and cannot find where it is. Has anyone done this and can you tell me the steps? Thanks!
- Mar 07, 2022
Thanks for the help. I figured it out by logging out and then clicking that I could not remember my password rather than asking for a one time password. They then sent me a link to re-set the password.
Mar 06, 2022Guru - Experienced User
Does it give a Forgot Password option?
https://kb.netgear.com/000038785/How-do-I-reset-my-NETGEAR-account-password
SJPWOLFF
No. It sent me a single use password. I planned on going in and changing my password but can't figure out where to do that. Logically, it should be in the profile section but . . . as with a lot with this website, I don't find it logical, and can't find it.
- FURRYe38Mar 06, 2022Guru - Experienced User
Its under Manage Profile/Log In Settings...
