SJPWOLFF
Mar 06, 2022Aspirant
How to change my password for netgear.com
Hi there. I've spent 30 minutes looking around the options on the website to change my password and cannot find where it is. Has anyone done this and can you tell me the steps? Thanks!
- Mar 07, 2022
Thanks for the help. I figured it out by logging out and then clicking that I could not remember my password rather than asking for a one time password. They then sent me a link to re-set the password.
Mar 10, 2022Guru - Experienced User
Seems like they did figure it out. Thanks for posting though.
emmyjohn01 wrote:
You can go login page then try to rest your password. i hope you can succesfuly reset your password.try it thank you.
