SJPWOLFF
Mar 06, 2022Aspirant
How to change my password for netgear.com
Hi there. I've spent 30 minutes looking around the options on the website to change my password and cannot find where it is. Has anyone done this and can you tell me the steps? Thanks!
- Mar 07, 2022
Thanks for the help. I figured it out by logging out and then clicking that I could not remember my password rather than asking for a one time password. They then sent me a link to re-set the password.
aleensmith32
Mar 10, 2022Aspirant
SJPWOLFF wrote:Hi there. I've spent 30 minutes looking around the options on the website to change my password and cannot find where it is. Has anyone done this and can you tell me the steps? Thanks!
i think you need to go login dashbord and click on reset password then reset and re enter new paassword.
- FURRYe38Mar 10, 2022Guru - Experienced User
That only works for the router log in, not the netgear.com user account.
