Emanres
Mar 24, 2020Aspirant
How to change SSID on router
I have a Netgear C6900 cable modem, and a Netgear Nighthawk R6700 v3. The router is one the other end of my house and connected to the cable modem with an ethernet cable. I want to use the router ess...
- Mar 25, 2020
Emanres wrote:Thank you for replying! I wasnt aware of the term "mesh device" but it sounds like that is what I actully want. What device(s) could Ireplcae mine with to accomplish this? have a 100gbs connection and I dont want the equipment to slow it down.
I do not know how to check the firmware on the router.
I did selcet AP mode during set up.
Maybe every time I try to access the router, I am acully accessing the modem, so I am not seeing the option for changing the SSID's on the router. Im not sure how to tell.
I doubt you have 100gbps. Maybe 100mbps. :)
there's a basic mesh setup like running a mesh extender. (see netgears extender page, they're labeled mesh)
Or a true mesh setup like orbi where its a fully integrated system with router/satellites.
Firmware on the router should be on the top right or status page when you log into it.
You should be able to get the ip address for the Netgear device by logging into your primary router and looking at the attached device page (or equivelent for your router).
Worst case? Factory reset the netgear device. Then during setup, change the ssid/password to what you want. Then place it in ap mode.
Mar 25, 2020Guru - Experienced User
1. what firmware is on the router?
2. What mode did you put the R6700 in? AP mode, router mode, what did you setup?
You're best bet is to setup the R6700 in AP mode (hardwired in like you have it). You can set the ssid's the same. Because neither device is a mesh device, you're devices might be "sticky" in that they don't as easily roam but you will be able to move throughout the house.
When the R6700 is in AP mode, you should be able to change the ssid by accessing it. Just do it fromt he browser and not the app for ease.
- EmanresMar 25, 2020Aspirant
- plemansMar 25, 2020Guru - Experienced User
lol, yes 100mbs. Thanks for all the information!
