IowaRoger
Mar 29, 2017Aspirant
How to change the SSID of an Access Point?
 I have two Netgear Nighthawk routers. The first router is connected to a DSL modem.  The second router (R6700v2) is connected to the first as an Access Point.  Previously, I successfully accessed the...
- Mar 29, 2017Log into the first router and look at the list of attached devices. The IP address of your second router will be listed. Use that IP address to log into the second router.
TheEther
Mar 29, 2017Guru
- IowaRogerMar 29, 2017AspirantThank you for your response. I am now able to change the SSID. I was able to access the Access Point router after a power down/up and using www.routerlogin.com. I don't know why it didn't work previously. In any event, this problem is now solved. Thanks !!
