rwadraa7's avatar
Dec 12, 2021
How to change the SSID or password
i want you guys to answer me that how can i change the SSID or password of my router ???
1 Reply
  • plemans's avatar
    You didn't tell us what router you have and you put that you have an A6210 which is a wireless usb device.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
