Habibu2's avatar
Habibu2
Follower
Jul 02, 2021
How to check my AC1900 wifi Cable modum router model C7000v2 configuration
How do I check my Netgear AC1900v2 WIFI modum router Model C7000
1 Reply
  • > How do I check my Netgear AC1900v2 WIFI modum router Model C7000
       "check" it for what?
       Is any of that an actual model number?  Look for "Model" on the
    product label.
          https://en.wikipedia.org/wiki/Modem
       A C7000[v2] is a modem+router, not a simple modem.
       You might try this radical concept:
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual (at least).  Read.
    Look for the LED descriptions and "Troubleshoot".  Further reading might
    not hurt, either.
    > Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
       Nothing to do with anything?
