jetman024
Nov 16, 2020Follower
How to check prior Logs for Netgear Router R7800
Every couple hours our Nighthawlk router loses wifi. All the lights turn off for a second then turn orange before regaining signal. Our modem does not lose signal and ISP confirms service was not los...
canepa
Nov 25, 2020Tutor
If your firmware is 1.0.2.76 or 1.0.2.74 you should revert to version 1.0.2.68
You can find more information here:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7800-Firmware-1-0-2-76/m-p/2007947
- JayboHNov 26, 2020Apprentice
Ok so awhile back what I did was factory reset by holding a toothpick in the reset button for half a minute just to be extra sure. When it asks you to update to the latest firmware (.76) I said yes.
Now here's the kicker: do NOT restore your saved settings. Put them in manually one by one.
I haven't had any issues at all now. You can see my past posts that .76 was giving me lots of problems until I did this (I discussed it in several threads, not just this one.)
