Jules_C's avatar
Jules_C
How to configure NETGEAR Nighthawk AC 4000 (R8000P) after switching to a 1GB Fiber ISP (Alta Fiber)?
I own a NETGEAR Nighthawk AC 4000 (R8000P) and it's been working fine with my initial ISP (Spectrum). I switched today to Alta Fiber (1GB Fiber). The ethernet connections are working, but the wifi co...
  • Jules_C's avatar
    Jules_C
    Sep 19, 2023
    "When you changed the service, did you reset the router to get it to forget past settings from the old ISP?"
    Thank you for your response. I had my Internet DNS hardwired to my initial ISP. Once I changed it to "Get Automatically from ISP" it worked.
