rguerra22's avatar
rguerra22
Follower
May 24, 2021
how to configure netgear x6 ac 3200 router
I would appreciate if someone out there can help me configure this router. It is supposed to be good but my wifi is spotty outside of the house.
  • What configuration issues are you having?  What do you mean it is spotty outside your house?
  • michaelkenward's avatar
    michaelkenward
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Look for the model number on the label on the device.
    Begin with the Quick Start/Installation Guide.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
    ac 3200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
