gvalenstein
Nov 03, 2016Follower
How to configure ReadyCloud
using Nighthawk X6 R8000 and do not see ReadyCloud option under ReadyShare options, only:
-Basic -ReadySHARE Printer -Netgear ReadySHARE Vault
I'm running newest firmware V1.0.3.4_1.1.2
- Nov 03, 2016
Hi gvalenstein,
Select the basic and you should be able to see tabs for ReadyShare, Media Server and ReadyCloud.
JamesGL
Community Team
JamesGL
Nov 06, 2016NETGEAR Employee Retired
Hi gvalenstein,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
