bbqmanone's avatar
bbqmanone
How to configure two wireless Engenius EAP600 access points to a Netgear AC1750
Hi, I'm currenly running an Engenius EAP600 wireless access point which is connected to my Netgear AC1750 router. I would like to add a 2nd EAP600 access point in a different location of my house an...
  • DarrenM's avatar
    Nov 12, 2019
    Yes, you would connect it the same way as the first one and assign it a new Ip and SSID.
    DarrenM
