Cong
Jun 09, 2019Follower
How to connect the D7000 to a Cable/Fiber Optic Modem
Could you show me how to setup connect NBN to Netgear Nighthawk D7000 router please? Basically NBN used WAN connect from setup box to the router.They not use the DSL connect from splitter.
> router please? [...]"NBN" could mean almost anything. What is the equipment supplied by
your (unspecified) ISP?D7000 or D7000v2? Firmware version?
> Basically [...]
Not a good start. "Exactly" would be more helpful than your
simplified "Basically" version of what is connected to what.> [...] used WAN connect from setup box to the router.They not use the
> DSL connect from splitter.What, exactly, is "setup box"? What, exactly, is "the router"? (Is
that the D7000[vX]?) (Which port? the D7000[vX] has multiple Ethernet
ports.) What, exactly, is "splitter"?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for
something like "Set Up the Modem Router for Cable or Fiber Service".
Note that this part of the R7000v2 User Manual is lousy with errors,so, if you have a "v2", then you might want to look at the R7000[v1]
User Manual, too.
1 Reply
> Basically [...]
User Manual, too.
