ANNOYED510
Jun 20, 2021Follower
HOW TO CONNECT this trash R6900 TO ANOTHER router
ok im trying to connect this r6900 nughthawk router to an existing router I have already setup on my home network. but the r6900 router is not allowing me to enter to admin settings through network ...
Jun 21, 2021Guru - Experienced User
maybe some more info is needed.
1. what router are you connecting it to?
2. are you setting it up as a wireless bridge or hardwiring it into the router?
3. firmware on the R6900?
4. Have you tried setting it up using a direct connection method? (hardwiring into it)
