jac189's avatar
jac189
Initiate
Nov 04, 2016
How to connect wireless printer wirelessly to netgear nighthawk AC3200 without a USB cable
I don't have the cable for the wirless wifi brother printer and got a new router nighthawk X6 AC3200. It seems the only way to connect is through a USB port. Is there a way to configure it wirelessly...
  • TheEther's avatar
    Nov 04, 2016
    You should be able to connect your printer to the Wi-Fi network by using the controls on the printer.
