DasCapitolin's avatar
DasCapitolin
Follower
Sep 27, 2022
How to create privileged route to bypass DoS filter?
Whenever I attempt to backup my computer data to iDrive cloud servers, my Netgear Nighthawk X4S R7800 router at detects a DoS attack (ACK Scan) and blocks my network connection to the router until I ...
  • michaelkenward's avatar
    Sep 27, 2022
    DasCapitolin wrote:
    Whenever I attempt to backup my computer data to iDrive cloud servers, my Netgear Nighthawk X4S R7800 router at detects a DoS attack (ACK Scan) and blocks my network connection to the router until I reboot.
    Have you tried to Disable Port Scan and DoS Protection?
    ADVANCED > Setup > WAN Setup
    Most of those reports of DoS attacks are false positives.
    I would look elsewhere for the source of your problems.
    What messages do you see when the router blocks the connection?
