AsbjornBrask
Jan 15, 2021Follower
How to disable AP Isolation
Hi I have to connect my Chromecast gen 3 to my wifi but when i connected it it just say on the google home app that i have to disable AP isolation but i cant find such a setting in the app. Do any o...
DarrenM
Jan 21, 2021Sr. NETGEAR Moderator
AP isolation is only a thing on the guest network on Netgear routers.
DarrenM
Scvenuto66
Jul 27, 2022Aspirant
I can't seem to find anyone who will explain the steps to disable the ap isolation on this netgear router. Can you help me ?
- michaelkenwardJul 27, 2022Guru - Experienced User
What Netgear devices are you using?
