Badock
Oct 19, 2019Tutor
How to disable DHCP on R7000P
I can uncheck the DHCP box on Advanced/Setup/LAN Setup but when I attempt to Apply the changed configuration, I get the error message "The IP address conflicts with the WAN IP subnet. Please enter a ...
- Oct 28, 2019
Success!
I'm on the latest firmware: V1.3.1.64_10.1.36
I did a hard reset and reconfigured the router. On the page Advanced/Setup/LAN Setup, I changed the router IP to 192.168.10.1 and hit Apply. Once the router rebooted, I changed the IP back tp 192.168.1.1, turned off the DHCP Server and hit Apply. Also turned on the DHCP Server on the Pi-Hole. This got everything working. Apparently the router wants to see a change in it's IP address when turning off the DHCP Server. I don't know why.
antinode
Oct 19, 2019Guru
> [...] looks like a bug to me. [...]
I agree.
> [...] reinstalled the firmware [...]
You might try loading some different/older firmware but I wouldn't
expect much.
Badock
Oct 19, 2019Tutor
Thanks, I'll try older firmware. But I think you're probably right, it will likely not help.
Also, I said the DNS server was working fine on the Pi-Hole. Not quite true. Every request shows as coming from the router (192.168.1.1) which decreases the usefulness of the Query Log. DNS Requests should be forwarded by the router (pass through) rather than answered by proxy.
