Badock's avatar
Badock
Tutor
Oct 19, 2019
How to disable DHCP on R7000P
I can uncheck the DHCP box on Advanced/Setup/LAN Setup but when I attempt to Apply the changed configuration, I get the error message "The IP address conflicts with the WAN IP subnet. Please enter a ...
  • Badock's avatar
    Badock
    Oct 28, 2019
    Success!
    I'm on the latest firmware: V1.3.1.64_10.1.36
    I did a hard reset and reconfigured the router.  On the page Advanced/Setup/LAN Setup, I changed the router IP to 192.168.10.1 and hit Apply.  Once the router rebooted, I changed the IP back tp 192.168.1.1, turned off the DHCP Server and hit Apply.  Also turned on the DHCP Server on the Pi-Hole.  This got everything working.  Apparently the router wants to see a change in it's IP address when turning off the DHCP Server.  I don't know why.
    Thanks to antinode  and schumaku  for your help.
