RayB398
May 13, 2020Tutor
How to disable DNCP on the R7000 as Access Point
Hi, I am using the nighthawk router as access point on the first floor of my house with an additional wifi network. However, dhcp cannot be switched of and now it interferes with dhcp on the router o...
- May 13, 2020
Can you set the router in Router mode and disable DHCP by unchecking the "use router as DHCP server" box?
microchip8
May 13, 2020Master
You're doing something wrong. If you put the router in AP mode, DHCP should be automatically disabled (and a few other things as well). How did you put the router in AP mode?
antinode
May 13, 2020Guru
> [...] DNCP [...]
"DHCP"?
> [...] R7000 [...]
> Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Which model is it? Look for "Model" on the product label. Firmware
version?
> [...] dhcp cannot be switched of[f] [...]
Says who? "cannot" is not a useful problem description. It does
not say what you did. It does not say what happened when you did it.
As usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] Is there a way to shut-off dhcp on the nighthawk while being an
> access point? [...]
It should be automatic/unavoidable, if you follow the instructions in
the appropriate User Manual.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for a
topic like "Set Up the Router as a WiFi Access Point".
