RayB398
May 13, 2020Tutor
How to disable DNCP on the R7000 as Access Point
Hi, I am using the nighthawk router as access point on the first floor of my house with an additional wifi network. However, dhcp cannot be switched of and now it interferes with dhcp on the router o...
- May 13, 2020
Can you set the router in Router mode and disable DHCP by unchecking the "use router as DHCP server" box?
microchip8
May 13, 2020Master
You're doing something wrong. If you put the router in AP mode, DHCP should be automatically disabled (and a few other things as well). How did you put the router in AP mode?
RayB398
May 13, 2020Tutor
Thx for responding so quickly, I use the web interface, tab advanced, advanced settings and then select AP. After doing that, the LAN and WAN settings are grayed out. And Even as AP, the router showes DHCP is on, next to the conflicts. Pls refer to attachment. Any advise what I can do otherwise?
Ray
- RayB398May 13, 2020Tutor
Attached the product details, apologies for all the typos and uncleareness of my problem statement.
firmware V1.0.9.88_10.2.88
thx,
Ray
- antinodeMay 13, 2020Guru
> [...] advanced, advanced settings and then select AP. [...]
That sounds right.
> [...] Even as AP, the router showes DHCP is on, [...]
That suggests that the firmware is defective. Either DHCP is really
on, even with "Operation Mode: Access Point", or else the indication is
wrong, and DHCP is really off.If you are sure that the R7000-as-wireless-access-point is your
second DHCP server, then I'd try a settings reset and manual
reconfiguration. If that doesn't help, then I'd try a different
firmware version.> firmware V1.0.9.88_10.2.88
Not everyone's favorite. The current consensus seems to be that
V1.0.9.42_10.2.44 is a better bet. There's also a newer version.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads. (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".) Find the
kit(s). Download the kit(s) you want. Read the "Release Notes" file
for instructions.
