RayB398's avatar
RayB398
Tutor
May 13, 2020
How to disable DNCP on the R7000 as Access Point
Hi, I am using the nighthawk router as access point on the first floor of my house with an additional wifi network. However, dhcp cannot be switched of and now it interferes with dhcp on the router o...
  • microchip8's avatar
    microchip8
    May 13, 2020
    Can you set the router in Router mode and disable DHCP by unchecking the "use router as DHCP server" box?
