MAXBOYBOY2
Jun 07, 2021Follower
How to Disable Guest Networks on My Router R6700
michaelkenward
Jun 08, 2021Guru - Experienced User
Manuals are always a good place to start. Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Set Up a Guest Network.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
