luguanyu
Dec 27, 2021Aspirant
how to disable ipv6 firewall
my isp provide ipv6 connection, also I complete ipv6 configure and get success message using ipv6test.com I can connect my pc using my tablet with rd client via ipv6 address, but can not login my pc...
- Dec 27, 2021
Yoou cannot easily disable the IPv6 firewall, at least not throough the GUI
luguanyu
Thank you. Is all the netgear routers can not do this via web gui?
I think it's an important feature...
microchip8
Dec 27, 2021Master
Not through the GUI. You can enable Telnet (http://192.168.1.1/debug.htm) and run "ip6tables -F". Do note that some other process can enable the IPv6 rules.
- luguanyuDec 27, 2021Aspirant
OK noted.
