AlanKUO
Dec 22, 2016Aspirant
How to disable R7000 ssh serivce ?
Hi , Does any one know how to disable R7000 ssh serivce? My R7000 be enabled ssh server and I cann't login it .
- Dec 22, 2016
AFAIK, the R7000 doesn't have an ssh server. To be safe, you should reinstall firmware to wipe out anything that may have been installed by a hacker. You should install the latest firmware in order to pick up the fix for the big security vulnerability that was publicized last week. Download the firmware here.
clithes
Dec 22, 2016Prodigy
If you can't login a Factory Reset may be the only way. This will unfortunately erase all your settings as well.
Page 192
Hope this helps
