AlanKUO
Dec 22, 2016Aspirant
How to disable R7000 ssh serivce ?
Hi , Does any one know how to disable R7000 ssh serivce? My R7000 be enabled ssh server and I cann't login it .
- Dec 22, 2016
AFAIK, the R7000 doesn't have an ssh server. To be safe, you should reinstall firmware to wipe out anything that may have been installed by a hacker. You should install the latest firmware in order to pick up the fix for the big security vulnerability that was publicized last week. Download the firmware here.
AlanKUO
Hi Clithes,
I had tried factory rest but ssh server on my r7000 still be enabled. Does ssh server default setting enabled? Or someone hacked my r7000 and enabled ssh (dropbear ssh server)
- TheEtherDec 22, 2016Guru
- AlanKUODec 22, 2016Aspirant
Hi TheEther,
I update the latest firmware OTA when I log on r7000 web at this morinig. but ssh still enabled. I downloaded the the latest firmware and reinstall it just. SSH service be disabled on my R7000. Thanks a lot!!
