AlanKUO's avatar
AlanKUO
How to disable R7000 ssh serivce ?
Hi , Does any one know how to disable R7000 ssh serivce? My R7000 be enabled ssh server and I cann't login it .
  • TheEther's avatar
    TheEther
    Dec 22, 2016
    AFAIK, the R7000 doesn't have an ssh server.  To be safe, you should reinstall firmware to wipe out anything that may have been installed by a hacker.  You should install the latest firmware in order to pick up the fix for the big security vulnerability that was publicized last week.  Download the firmware here.
