namlah1936
Nov 19, 2020Aspirant
HOW TO DISABLE THE 5 G BUT KEEPING THE 2.4G ACTIVE ONLY ON A AC 1750 SMART WIFI ROUTER
HOW CAN I DISABLE THE 5G ON A AC1750 SMART WIFI ROUTER AND KEEP THE 2.4G ACTIVE
namlah1936
Nov 20, 2020Aspirant
I have a sensi wifi thermostat that requires 2.4v for it to work properly
Nov 20, 2020Guru - Experienced User
You don't have to shut off 5ghz for it work. You simply have to have make sure the phone is connected to the 2.4ghz during setup of the thermostat.
You shouldn't need to but its lazy coding on the developers side that cause you to need to do so.
- namlah1936Nov 20, 2020Aspirant
I NEED ONLY 2.4V YO MY SENSI WIFI THERMOSTAT
- plemansNov 20, 2020Guru - Experienced User
1. Caps lock. you must have bumped it again.
2. so follow the guide i listed prior.
https://kb.netgear.com/24101/How-do-I-enable-or-disable-the-wireless-radios-on-my-Nighthawk-router
