gohopdrummer
Jan 13, 2023Aspirant
How to disable WPS button on R6800 router?
1. Is there a way to disable the WPS button on my R6800 router? If there is, I can't find it. 2. If I reset the router to factory settings, will the WPS button be enabled or disabled by default?
Jan 13, 2023Guru - Experienced User
Might check under Advanced Tab/Advanced Settings/Wireless settings to see if there is any WPS options. There may or may not be. Review the online user manual as well for WPS information.
gohopdrummer
Jan 24, 2023Aspirant
I haven't been able to find any solutions in the software itself, or the manual. I appreciate your effort, though. :O)
