gohopdrummer's avatar
gohopdrummer
How to disable WPS button on R6800 router?
1. Is there a way to disable the WPS button on my R6800 router? If there is, I can't find it. 2. If I reset the router to factory settings, will the WPS button be enabled or disabled by default?
