lmoldovanyi
Nov 18, 2020Aspirant
How to disable xfinity hotspot on Netgear router (AC1200 WiFi Cable Modem Router(C6220)
My kids have figured out how to bypass the parental controls on my Gryphon Mesh router, which is (redundantly, I realize, but I wanted the parental controls) connected to my Netgear router, by access...
antinode
Nov 18, 2020Guru
> [...] my Gryphon Mesh router [...]
Should I know something about that device?
> [...] I'm not seeing a setting for disabling the Xfinity hotspot.
How did you determine that your C6220, rather than one of your
neighbors' routers, is the source of this "free Xfinity hotspot"? Does
it vanish when you power off the C6220?
- lmoldovanyiNov 19, 2020Aspirant
Yes, that is exactly how I know that it's my own modem/hotspot and not my neighbor's. That was my very first troubleshooting step.
The only part worth knowing about the Gryphon Mesh router is that I bought after realizing that the Netgenie parental controls were inadequate and hard to use; however it's only a router and not a modem/router combination. So, since I couldn't return the Netgear modem/router, I now have both.
