lmoldovanyi
Nov 18, 2020Aspirant
How to disable xfinity hotspot on Netgear router (AC1200 WiFi Cable Modem Router(C6220)
My kids have figured out how to bypass the parental controls on my Gryphon Mesh router, which is (redundantly, I realize, but I wanted the parental controls) connected to my Netgear router, by access...
Nov 19, 2020Guru - Experienced User
Like antinode says, the "xfinity hotspot" probably isn't yours. I haven't found any netgears modems that have the xfinity hotspot integrated.
modem/router combo devices that is.
- labattNov 19, 2020Mentor
When Comcast does an install the modem/router also has a Xfinity hotspot option that they leave on. Supposed to be there for Comcast customers to connect to when not home. Like has been said, this is a neighbor that has the hot spot. Cannot block usage at your house.
- lmoldovanyiNov 19, 2020Aspirant
Interesting that everyone had the same answer that it isn't my own modem. It definitely IS my modem that is open/not-secured, and it is not that of any of my neighbors. I know this because if I unplug the modem, then I consistently lose the ability to connect to that wifi hotspot. I was already aware that Xfinity provides this as a service to communities and my first call was to them, but they said that it is something that can be controled only on the modem itself, not simply through my Xfinity account.
If anyone knows how to make the free xfinity hotspot either unavailable or password-protected, I'd appreciate the help. Thanks
