lmoldovanyi
Nov 18, 2020Aspirant
How to disable xfinity hotspot on Netgear router (AC1200 WiFi Cable Modem Router(C6220)
My kids have figured out how to bypass the parental controls on my Gryphon Mesh router, which is (redundantly, I realize, but I wanted the parental controls) connected to my Netgear router, by access...
lmoldovanyi
Nov 23, 2020Aspirant
I solved it, and I thought I'd share the solution with you since you all seemed unaware of this option but were kind enough to respond. Comcast customer support didn't seem to know anything about this either, so you're not alone. I stumbled onto it.
https://customer.xfinity.com/#/settings/security/hotspot-devices has a list of devices that at one point had logged into the xfinitywifi hotspot with a comcast username/password. I removed those devices. Problem is now solved.
Thanks again.
- plemansNov 23, 2020Guru - Experienced User
That doesn't disabled a hot spot. It just basically blocks devices from connecting to an approved xfinity hotspot.
But it'll function the same to block a device from connecting.
Just make sure the kid isn't able to log into your account to allow a device.
