Valkyrie99
Jan 10, 2022Tutor
How to downgrade R7900P to 1.4.1.68
I've seen posts about browser loading issues after upgrading firmware to 1.4.2.84, and the solution is suggested to downgrade to the previous version 1.4.1.68. Where can I get that version? I'm not...
- Jan 10, 2022
https://www.netgear.com/support/product/R7900P.aspx#download
Besure to select the Prior Versions.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Valkyrie99
Jan 10, 2022Tutor
Awesome, that was exactly what I needed. I performed the "downgrade" and the problem went away. Now hopefully Netgear will fix the problem and provide a new firmware update!
Much obliged!
sloanish
Jan 12, 2022Aspirant
I had intermittent errors after upgrading to R7900P-V1.4.2.84_1.3.42.zip
Happened on wired and wireless
Had to downgrade back to R7900P-V1.4.1.68_1.3.28.zip
Foloowing this to see if there is anymore progress
Error was as follows
Hmmm... can't reach this page
Check if there is a typo in www.example.com
DNS_PROBE_FINISHED_NXDOMAIN
- Valkyrie99Jan 12, 2022Tutor
That was the same issue I encountered as well, and the downgrade to the previous firmware version immediately resolved the issue. I haven't heard (or looked to see) if Netgear fixed this problem yet.
