Stinsonddog
Nov 21, 2021Star
How to enable iCloud Private Relay to work?
What is needed in Advanced settings to ALLOW the mask.icloud.com
mask-h2.icloud.com I see block sites in my Advanced Control Panel but not allow sites.
- Nov 28, 2021
I have this working. Note I can't access the router with it on. Not sure what did it but I discoved that MU-MIMO wasn't on and turning it on helped general connectivity alot. It is under advanced wireless settings. Maybe the router just needed a reboot. Private relay is working on a variety of devices now. I did turn UPnP off. Hope that helps.
Stinsonddog
Nov 21, 2021Star
This is what the Advanced panel looks like.
- StinsonddogNov 21, 2021Star
This board is not taking my screen shot and won't let me edit the prior posts.
- michaelkenwardNov 22, 2021Guru - Experienced User
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
Your first images is now visible.
