Stinsonddog
Nov 21, 2021Star
How to enable iCloud Private Relay to work?
What is needed in Advanced settings to ALLOW the mask.icloud.com
mask-h2.icloud.com I see block sites in my Advanced Control Panel but not allow sites.
- Nov 28, 2021
I have this working. Note I can't access the router with it on. Not sure what did it but I discoved that MU-MIMO wasn't on and turning it on helped general connectivity alot. It is under advanced wireless settings. Maybe the router just needed a reboot. Private relay is working on a variety of devices now. I did turn UPnP off. Hope that helps.
Stinsonddog
Nov 21, 2021Star
This is what the Advanced panel looks like.
Stinsonddog
Nov 21, 2021Star
This board is not taking my screen shot and won't let me edit the prior posts.
- michaelkenwardNov 22, 2021Guru - Experienced User
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
Your first images is now visible.
