Stinsonddog's avatar
Nov 21, 2021
How to enable iCloud Private Relay to work?
What is needed in Advanced settings to ALLOW the   mask.icloud.com mask-h2.icloud.com I see block sites in my Advanced Control Panel but not allow sites.
  • Stinsonddog's avatar
    Nov 28, 2021
    I have this working.  Note I can't access the router with it on.  Not sure what did it but I discoved that MU-MIMO wasn't on and turning it on helped general connectivity alot.    It is under advanced wireless settings.  Maybe the router just needed a reboot.  Private relay is working on a variety of devices now.  I did turn UPnP off.  Hope that helps.
