Vinadiak
Feb 22, 2021Aspirant
How to enable telenet in R6400
I want to enable telnet in R6400,but I don't how to enable it.Please help me!
Mickatroid
Not sure what you mean. Do you want to telnet to the router? Last time I tried telnet to a telnet service just worked in a browser without any drama or extra config.
- VinadiakFeb 23, 2021Aspirant
As you say! I want to telnet my router,but I can't do it . its telent service not work.I don't how enable it.
- michaelkenwardFeb 23, 2021Guru - Experienced User
Vinadiak wrote:
As you say! I want to telnet my router...
Why? Maybe you can achieve what you want without that.
Can you login to http://routerlogin.com?
If so, go to:
http://routerlogin.com/debug.htm
Some, but not all, devices will then allow you to enable Telnet.
This is the sort of feature that Netgear changes with firmware updates.
If it fails for you, it may be possible to do this with older firmware.
Okay! I find an older firmware that can start it. but if can. I want know some other way to start it in the new firmware
