Vinadiak
Feb 22, 2021Aspirant
How to enable telenet in R6400
I want to enable telnet in R6400,but I don't how to enable it.Please help me!
Vinadiak
Feb 23, 2021Aspirant
As you say! I want to telnet my router,but I can't do it . its telent service not work.I don't how enable it.
michaelkenward
Feb 23, 2021Guru - Experienced User
Vinadiak wrote:
As you say! I want to telnet my router...
Why? Maybe you can achieve what you want without that.
Can you login to http://routerlogin.com?
If so, go to:
http://routerlogin.com/debug.htm
Some, but not all, devices will then allow you to enable Telnet.
This is the sort of feature that Netgear changes with firmware updates.
If it fails for you, it may be possible to do this with older firmware.
- VinadiakFeb 23, 2021Aspirant
Okay! I find an older firmware that can start it. but if can. I want know some other way to start it in the new firmware
- antinodeFeb 23, 2021Guru
> [...] I find an older firmware [...]
Which?
Define "new". Which ones fail?
Complain to Netgear? It's their firmware. They "improved" it.
