BRIANWILHELM
Feb 09, 2021Follower
How to establish a bridge connection between two Nighthawk Mesh routers
Hello, I have recently purchased two sets of the Nighthawk Mesh Routers with Satelites. I will be placing one router in our adminisration building where there will be a access the the MediaCom Modem....
antinode
Feb 09, 2021Guru
> How to establish a bridge connection [...]
"bridge" is a widely misunderstood/misused term.
> [...] two Nighthawk Mesh routers [...]
Actual model numbers would be more helpful. Look for "Model" on the
product label.
> [...] set up the other router (bridge) in another buliding (85 ft)
> away and connect with a CAT6. [...]
Sounds as if you want to configure the remote router as a wireless
access point.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for a topic like "Use the Router as a WiFi Access Point".
